Case Study: Linking Barcode Technology to Quality Control
Barcodes enable companies to store a wealth of information about each part in their inventory. Source: Hexagon Metrology |
Scanning the way to productivity.
Few could have guessed that chewing gum would usher in an era of streamlined production, reduced costs, and unparalleled traceability. In June 1974, a 10-pack of Wrigley’s Juicy Fruit did just that as it became the first product scanned with a universal product code (UPC). Although not the catalyst for sweeping adoption of barcode technology across the manufacturing sector, the event is the most memorable with the pack on display at Smithsonian’s Natural Museum of American History in Washington D.C.
In reality, barcodes had been in existence since US patent number 2,612,994 for a ‘Classifying Apparatus and Method’ was issued in October 1952. Though the technology was slow to take off, it eventually made its way into several aspects of everyday life. Besides retail settings, barcodes are routinely found in manufacturing and assembly facilities. Companies adopting barcode technology typically custom design a system to fit their needs depending on what information they must capture. Surprisingly, few companies have carried the technology through to their quality control departments. The application of barcoding technology to quality control unlocks the potential to improve quality procedures and help error-proof the final steps before products are shipped.
The Benefits of Barcodes
As industries learned long ago, having automated systems to interpret information dramatically improves data integrity while reducing the time needed to perform such operations. The benefits barcode technology brings to industry are numerous, but generally may be classified into three main categories: a decrease in data entry error, a decrease in inspection time, and an increase in traceability.
A standard, off-the-shelf scanner interprets 1D and 2D barcodes. Source: Hexagon Metrology |
GS1 is a non-profit group dedicated to the design and implementation of global standards throughout supply chains. They state a skilled data entry operator will make one mistake in 300 keystrokes. Barcodes, on the other hand, reduce data entry error to an estimated 1 in 1 million keystrokes – well over 3,000 times the accuracy of a human. Since part numbers can easily be 10 to 20 digits long, at some point digits will get transposed and mistakenly added or subtracted. This corrupted information pollutes the database with non-standard inputs making statistical analysis difficult if not impossible.
Barcodes also reduce the time spent inspecting components. When a company has thousands of part programs to choose from, time is wasted searching for the correct one. There is also the potential for human error leading to an incorrect program or revision level being selected. Scanning the part’s barcode on the job ticket instantly pulls the correct program from memory.
The final category relates to an increase in traceability when a barcode system is implemented in the quality department. When barcodes identify components and materials, traceability is greatly increased. This also applies a level of accountability to not only the operator inspecting the part, but also to the machine that inspected it, the machine that manufactured it, and even the batch number of the material used in its creation. If there are any concerns at a later date, it is simple to single out the employee, equipment, batch, or even vendor which may be responsible.
Implementing Solutions
Since all barcode technology uses a pictorial representation to relay data to a computer, it is essentially no different from a keyboard. Barcode scanners translate the information and act as a virtual typist inputting data at the rate of 40 to 200 characters per second. Therefore, when deliberating the potential solutions to introduce barcodes to the quality control department, an organization should consider all points of data entry. It should also consider the amount of information needed at each step of the quality control process. The data capacity embedded in each barcode varies by the technology used – the standard one-dimensional 13 digit barcode system can produce ten-thousand billion unique codes, but is limited to the 13 characters of actual data input. Two-dimensional barcodes, such as QR codes, can contain about 100 times more usable information.
Each company may discover different uses for barcode technology according to their unique situation. In the quality control department, application may be considered at any point in the part program: before, during or after it is run.
Before running the program, as mentioned previously, barcodes can be utilized on job tickets to encode a variety of traceability information related to that job. A company might choose to encode part numbers, operator employee numbers, operator instructions, and lot numbers. This information can be automatically added to input fields on the inspection report to ensure proper recordkeeping. Barcodes could also be used to identify a part program’s filename to ensure the correct inspection routine is run. Metrology inspection software such as PC-DMIS (Hexagon Metrology) allows for programmatic data input during an inspection routine and is able to take this information and automatically begin the inspection routine.
Scan these barcodes with a smartphone or handscanner for the answer. Source: Hexagon Metrology |
During the part program, a company currently using QR codes, or other 2D barcode technology to label inventory, has the capability of including nominal values as part of the information stored within them. When the individual part or its bin is scanned, the theoretical x, y, and z values are instantly pulled. Normally this data is either hard-coded into the software or the operator manually inputs the values. Using barcodes and program input fields, the user interface form can be automatically populated when the code is scanned.
This feature is beneficial to a facility that has several new parts that require parametric programming (See Sidebar). Previously, the operator had to manually enter each new nominal value before the program was run. Now the values can be entered into a spreadsheet which is then copied and pasted into a barcode generating program. The resulting barcode is affixed to the part’s bin and contains all required information, as well as the identification of the parts program. A scan of the barcode uploads the data to PC-DMIS and the inspection routine begins automatically.
Hexagon Metrology, Inc.
(847) 931-0100
www.HexagonMetrology.us
SIDEBAR |
After the part program is run, barcodes may also be placed on the parts themselves, using labels or pin stamping for example, to include information on measured features. If a concern surfaces at a later date, the component may be scanned and the original measurement information will be revealed. Because of the original data integrity, the scan can also break information down to trace the materials, lots, vendors, machinery, and employees involved with the part’s creation. This is particularly beneficial to the aerospace, automotive, medical or energy industries where traceability must be documented for safety and recall purposes.
The Next Step
Using barcode technology throughout a manufacturing or assembly facility makes good business sense. With all the benefits it offers, it understandably has become one of the most widespread technologies in supply chain management. For a company currently using barcodes to track inventory, it is a small step to carry it through to their quality control department. Since each facility is unique, expert consultation should be the first step in discussing the potential upgrade. For example, Hexagon Metrology’s applications services group has expertise in barcoding hardware technology, user interface programming, parametric part programming, and typical application of barcoding to the quality control function is essential to a successful project outcome.
As the 60th anniversary of the barcode’s patent approaches, the world has taken great steps forward in reaping all the benefits it has to offer. The pack of chewing gum that changed the world was just the beginning of the revolution that transformed the supply chain. As organizations apply barcode technology to their quality control departments, they will undoubtedly realize decreased errors, increased speed, and traceability. In a sense, their world will never be the same again.
