Quality certification is for professionals who know the chosen specialty so well that they can apply the knowledge with known results. The professional knows their own strengths, and the limitation of the specialty.
Times change, technologies change, but the fundamentals of leak testing remain the same – the reliability and repeatability of your test results depend on how well you understand and compensate for testing variables.
A Growing Number of Manufacturers are Using Deep Learning Tools, a Subset of Artificial Intelligence, to Reduce Waste and Improve production. But, Experts Say, Some of it is Just Hype.
An increasing number of manufacturers are turning to deep learning, a subset of artificial intelligence (AI), to assist in image analysis processing, experts say.
As a branch of metalworking, a subset of fabrication, metal forming is a foundational process, involved in a wide range of parts assembly: from the metal stamping of consumer goods used at home to many of the component elements of airplanes and automobiles.
There are three primary options available today for shaft measurement: optical, tactile, and a combination system. The optical systems have become common over the past few decades because of their flexibility and speed. So how do you choose the best option for your specific application?
Quality standards require that measuring equipment be calibrated prior to being put into service. In addition, the maintenance of measuring equipment requires recalibrations at regular intervals.
Several critical components need to come together to form a machine vision system. This includes the sensor (typically within a camera) that captures a picture for inspection, the processing hardware (a PC or vision appliance) and software algorithms to render and communicate the results. In addition, lighting, staging, and lenses are required to set up a machine vision system.
Calipers are an integral tool for many applications, yet they’re a tool that likely doesn’t garner much reflection. Whether you’ve been using them for years or are investing in them for the first time, here are the ins and outs of caliper design and use that you’ll want to keep in mind.
There is a long-standing practice in the computer aided inspection industry that includes CMMs to report in-tolerance values in green and out-of-tolerance values in red.
Screw thread inserts (STI) require the threaded hole to be inspected prior to inserting the threaded insert or coil. The dimensions and tolerances for the gages used to inspect these threads have been a bit confusing over the past 30 years.
