Would it shock you to learn that spending on artificial intelligence is on the rise? According to respondents of our Annual Quality Spending Survey, 55% of companies expect to increase their spending on AI for 2024.
A Q&A with Reed Switch Developments Corp. president Debra Dahlin, and Engineering and QA Manager, Jeff Rosenbaum, to talk more about its holistic approach to quality.
We will explore the use of CMMs, advancements in technology, and their growing contribution to support leading developments in automation, artificial intelligence, and machine learning.
The eddy current scanning solution that was developed for hard to access HPCR spool areas represents a reliable inspection platform that produced repeatable results.
Advanced 3D digitalization technologies offer a solution with a modernized NDT alternative that saves time and money and unlocks access to more information in a single measurement session.
Whether you are an OEM testing an airframe or a third tier supplier testing high strength alloys, it is crucial to use a reliable tensile testing system that can produce repeatable results.
The continuous ground-breaking advances in the aerospace industry put more and more pressure on nondestructive testing (NDT) equipment manufacturers to be proactively solving new inspection challenges. As such, the recent advances in eddy current array (ECA) have considerably expanded the range of components and assets that can be inspected for surface and near-surface flaws.
Aerospace has a large, diverse, global supply chain. It is also struggling to keep up with demand while maintaining the essential quality and conformity of the products and services.
While PAUT is becoming a popular approach for nondestructive inspections, it is important that users understand this technology, its limitations and how it should be applied.
The vast digital loop across key domains that CT analysis can play a role in allows it to contribute critical insights back to design from embedded simulation and virtual metrology testing, as well as all phases of process examination and related refinements.
