Design of Experiments Uncovers Hidden Factors in Production Processes
Image Source: gorodenkoff / iStock/Getty Images Plus
Design of Experiments helps manufacturers improve products and processes faster and more efficiently by testing multiple factors at once.
At its core, DOE tests how several factors work together to affect a product, instead of changing just one thing at a time. This gives a fuller picture of what influences the end result.
The benefits of DOE in manufacturing are numerous:
- Efficiency: By allowing multiple factors to be tested concurrently, DOE significantly reduces the number of experiments needed. This translates to savings in time and resources, which translates to faster product development and process optimization.
- Interaction Detection: DOE finds hidden connections between factors that simpler experimental designs can miss. Because multiple variables often influence a product’s final level of quality, the ability to spot complex interactions matters.
- Broad Applicability: From automotive to food production, DOE can be applied across various manufacturing sectors. It's equally effective for optimizing chemical formulations, machine settings or product compositions.
- Robustness: Beyond finding optimal settings, DOE helps identify process parameters that are less sensitive to uncontrollable variations. This leads to more stable manufacturing processes and consistent product quality.
- Predictive Power: After conducting a DOE, manufacturers can predict outcomes for factor combinations not directly tested — which is invaluable for further optimization without additional testing.
The DOE process typically follows these steps:
- Define the objective (e.g., reducing defects, improving strength)
- Identify factors to be varied
- Design the experiment using statistical software
- Conduct the experiments and collect data
- Analyze results to determine optimal settings and factor interactions
One of DOE's strengths is its efficiency. A well-designed experiment can provide comprehensive insights with a surprisingly small number of runs. For instance, a study involving 5-6 factors might require only 16-32 experimental runs, a fraction of what would be needed in exhaustive testing.
As manufacturing becomes increasingly complex with the advent of technologies like 3D printing and smart factories, DOE provides a structured approach to understanding and optimizing these complex systems.
