The new extended travel machine features a 24” x 24” x24” envelope and tilt and rotary axes based in a trunnion configuration, which can accommodate parts weighing up to 100 lbs.
Owners of Hurco vertical machining centers will have the ability to transform their WinMax part programs to a 3D printed rapid prototype directly on their CNC machine using an optional spindle-powered wireless accessory.
RVP, Renishaw’s new vision measurement probe for use with the REVO 5-axis measurement system on co-ordinate measuring machines (CMMs), increases the multi-sensor capability of REVO by adding non-contact inspection to the existing touch-trigger, high-speed tactile scanning and surface finish measurement capability of the system.
The new Delcam CAM software algorithms in PowerMILL have made programming 5-axis mills easier than ever before, including digitally verifying the code for safety once programmed.
Newage Testing Instruments introduced the latest addition to its HMV-G family of microhardness testing systems: The semi-automatic HMV-G21. The HMV-G21testing system is so easy to use that the testing will seem like a breeze even to new and inexperienced users.
The new GLX-3 Laser Welders from Branson Ultrasonics, a business of Emerson, delivers clean, high speed laser welding of large-format plastic parts with more complex geometries to meet the growing needs of automotive, appliance, medical, filtration, and other applications that require particulate-free welds with superior aesthetic quality.
Fluke Calibration introduces the 2271A Industrial Pressure Calibrator, a comprehensive, automated solution for calibrating a wide variety of pressure gages and sensors. The 2271A is ideal for calibration laboratories that are adding pressure calibration services because it features a broad range of pressure measurement capabilities in a single instrument.
With its broad range of measurement accessories, the new Multimar 25 EWR Digital Universal Caliper from Mahr Federal is a versatile and configurable caliper for ID and OD measurement requirements.
