LARGO, FL, July 24-Ametek Calibration Instruments announces that the Jofra range of industrial pressure indicators (IPI) is now ATEX and CSA certified for use in potentially explosive environments in the field or in calibration laboratories. ATEX is the primary intrinsically safe standard in the European Union while CSA refers to relevant Canadian and USA standards.
Accurate to ± 0.05% FS, the Jofra IPI can be used as a calibration reference or in applications where high-accuracy pressure measurement is required from safety valve checks to system pressure verification. This new certification will allow the IPI to be used in any industry where there is a risk of flammable gases.
The indicators are available in 10 different pressure ranges. An RS232 interface is supplied as standard, which can be used for configuration, calibration and to transfer measurement data from the gage.
Ametek Receives ATEX, CSA Certification
