EXAIR’s new 1-inch Stainless Steel Flat Super Air Nozzle™ produces a flat 1-inch (25mm) wide airstream with a strong blowing force of 9.8 ounces (278g) when mounted 12 inches (305mm) from the target. The unique design of this super-efficient nozzle makes it an ideal fit for both tight spaces and tight budgets, plus the Type 316 stainless steel construction makes it ideal for corrosive, high temperature, food and pharmaceutical environments.
The 1-inch Flat Super Air Nozzle uses EXAIR’s patented technology to maximize entrained airflow while reducing noise levels. A precise amount of air is released through the .015 inch (0.38mm) air gap opening that is set with a stainless steel shim positioned between the body and removable cap. The high velocity airstream pulls in surrounding room air to produce a wide, forceful stream of laminar airflow. Air consumption is 10.5 SCFM at 80 PSIG. Force and flow may be easily adjusted by installing different shim thicknesses.
The 1-inch Flat Super Air Nozzle is also available in zinc aluminum alloy construction, suitable for rugged industrial applications. Applications include ejecting heavy parts and slugs, chip removal, part cleaning, drying, liquid blowoff and cooling.
EXAIR Corporation
(800) 903-9247
[email protected]
www.exair.com/1sanss.htm
