The Distec from Schenck with its vertical measuring spindle is the ideal automatic balancing machine for disc-shaped rotors. Unbalance correction of disc-shaped rotors is typically accomplished by removing material vertically or horizontally depending on the application. The Distec performs either correction method with an adjustment of the drill correction unit.
SCHENCK
(631) 242-4010
WWW.SCHENCK-USA.COM
BOOTH E-5843
