Olympus Corporation announced the global launch of its IPLEX® GX/GT industrial videoscopes, new products in its scientific solutions business for manufacturing and maintenance inspection applications.
Phillips Precision’s Products Division announces its new 3-Legged Spider-Clamp™ as part of the Inspection Arsenal® LEAN, Quick-Swap inspection fixture system.
Mark-10 introduces their all-new G1105 Cork Extraction Fixture, designed for measuring the pull-out force of a cork stopper from a bottle. By measuring the extraction force, bottlers can ensure a satisfying customer experience, while maintaining the freshness of the contents.
Magnaflux is introducing a new multi-direction magnetic particle wet bench – one that is specifically designed for speed. The Universal WE wet bench is designed with automotive customers in mind.
Carestream Non-Destructive Testing introduces the new wireless HPX-DR high resolution digital DR detector that provides higher resolution, heavy duty shielding, optimum portability and improved workflow for use in many NDT mobile and lab inspection applications.
Mahr Inc. announced a new family of Micromar 40EWRi-L digital micrometers with high speed measuring spindle positioning. The digital micrometers, with the latest MarConnect interface, allow measurements that are 10 times faster than a standard micrometer, saving the operator time when numerous different dimensions need to be measured on a single workpiece.
Emergent Vision Technologies launched The Accel Series, 25GigE Line Scan cameras. The EVT Accel Series by Emergent Vision Technologies is the first ever to utilize the 25GigE interface standard.
Cal Test Electronics introduces its new CT4200 series of passive voltage oscilloscope probes featuring compact 2.5 mm barrel size and bandwidths from 55 MHz to 1.5 GHz. The 8 model series includes 1x, 10x, 20x, and 100x attenuation ratios.
