Bruker’s UMT TriboLab™ can perform practically every common tribological test on nano and micro scales with higher speeds, more torque, and better force measurement than any of its predecessors or competitors, plus it introduces powerful new features for improved efficiency and ease-of-use.
CoreX2 the largest Field of View OASIS that measures multiple dimensions on a part to an accuracy of up to +/- .0002 in. and with the addition of the Motorized Rotary Stage, parts can be rotated a full 360-degrees to get profile images and measurements from every aspect of the part.
The Polytec TopMap Pro.Surf is a non-contact surface metrology system ideal for reporting parameters such as flatness, step-height, parallelism and waviness.
When working with applications in spindles, grippers, and robotics, space is typically very tight. Unfortunately, that fact does not eliminate the need for automation. If anything, it increases it.
