A long-distance model of the Heat Spy thermal imaging camera is available. The HSI3003 offers narrow angle 9.1- by 6.8-degree field-of-view optics, which enables detection and temperature measurement of small objects over long distances. The instrument is fully radiometric and measures the temperature of every pixel. Easy Report software allows the operator to insert multiple images with data taken during a site survey to produce an inspection report. The instrument has a temperature range of 32 to 482 F, and a trigger activated, Class II laser that identifies the problem hot spot shown on the marked center of the display. Two measurement cursors, movable anywhere in the image, provide temperature readings at each cursor location, and indicate real-time differential temperature measurement between the two points anywhere along the temperature range.
- Palmer Wahl Instrumentation Group
(800) 421-2853
www.palmerwahl.com
