Machine Vision at 90 FPS
The CleverDragon line of industrial-grade cameras is capable of up to 90 frames per second and all pixel data readout at VGA resolution. Featuring Power over Camera Link (PoCL) technology to allow transfer of image data, power and control signals on a single cable, the new cameras are optimized for semiconductor, packaging and other high-speed detailed inspection tasks. Two models are available in resolutions of XGA (1024 by 768) or VGA (640 by 480). Equipped with a full-frame shutter that allows all-pixel reading even during random trigger shutter operations, the cameras read data three times faster than conventional CCD cameras, while providing vertical resolution without degradation. Ideal for replacing existing monochrome analog cameras, both models have a compact form factor-29 millimeters by 29 millimeters by 26.5 millimeters. PoCL further assists the integrator by eliminating the need for separate power and control cables.
Toshiba Teli Corp.
(949) 770-8354
www.toshiba-teli.com
Reply 607
Toshiba Teli Corp.
(949) 770-8354
Reply 607
