2-D Profiling Laser Sensor
The model ZG 2-D profiling laser sensor completes a height and width inspection in a single pass in milliseconds, capturing entire shapes by measuring the X and Z axes. The sensor measures up to four items simultaneously, allowing accurate and stable inline measurement at full production speed. A real-time profile display on the controller’s built-in LCD monitor and its ease of setup enable the sensor to both reduce hardware costs and deliver profile data at a low cost.
A range of sensing heads capture profiles from 3 to 70 millimeters wide using a visible laser. Using remote triggering, the sensor can calculate the measurement value in sync with the command input, so that inspection timing is clearly known and determinate.
Omron Electronics LLC
(866) 88-OMRON
www.omron247.com
