Case Studies: Check Fixtures Save Time and Money
Marlin manufactures steel wire baskets, hooks and shelves. Go/no-go fixtures made by a CNC machine have helped the company speed up its production process and greatly reduce scrap. Source: Marlin Steel Wire Products LLC
As recently as November 2008, Marlin Steel Wire Products LLC (Baltimore), manufacturer of steel wire baskets, hooks and shelves, used to make one check fixture every four to eight hours. “We had situations where we would get an order, but because our fixture department was committed already, it would delay things in production,” recalls Drew Greenblatt, president of Marlin.
While at one time Marlin’s fixturing department was only able to make one or two check fixtures a day, the company now can make more than a dozen per day thanks to the 5012 computer numerical control (CNC) machine from AXYZ Automation Inc. (Cincinnati). Marlin Steel Wire invested in the CNC to automate production of go/no-go fixtures to check the specs and quality of its customers’ orders. With the new machine, an engineer at Marlin now can make a go/no-go fixture in about 20 minutes.
With the AXYZ 5012, engineers download the customer’s specifications to the router from the exact print. The mold, or go/no-go fixture, is created from the original print. “We no longer have somebody else reverse engineer it,” says Greenblatt. “We used to have the engineer make the print and a fixture maker would make a fixture with a Bridgeport milling machine.”
Consequently, with the manual gage-making process no longer in place, the company’s aluminum purchases have plummeted. Recycled sawdust, used by the CNC router to create the fixtures, is less expensive and more accurate than aluminum.
Engineers at Marlin discuss making a check fixture to suit a customer’s specifications. Source: Marlin Steel Wire Products LLC
The CNC machine has not only significantly sped up production, reduced scrap and improved quality, but because of the foolproof go/no-go gages that the machine produces, the company no longer needs highly trained staff checking the orders.
“The check fixtures make it simple for the employee on the factory floor who’s not aware of design issues to make sure the part is right the first time,” Greenblatt says. In fact, he adds, the manufacturer has reduced scrap so significantly that the company decreased its dumpster size from that of a tractor-trailer to that of a van. In real numbers, the company went from 8,325 pounds of stainless steel scrap in the last quarter of 2008 to an estimated 598 pounds of stainless steel scrap in the second quarter of 2009.
Another benefit is that the new machine helps Marlin to run as lean as possible. “We buy as much steel as we will make that day so if we have a job where there is a ‘boo boo,’ we don’t have the steel to make that up. We are shooting for no scrap. It’s expensive to make mistakes,” Greenblatt adds.
“The other benefit is that now that we have so many check fixtures, factory workers at every single operation can confirm the precision between each step of the process. So it’s not like we find out at the last step if there is a problem,” he says.
The CNC machine uses recycled sawdust to create go/no-go fixtures for quality inspections. Source: Marlin Steel Wire Products LLC
“Our customers are demanding better quality all the time. So to position ourselves as number one, I needed a method-a tool-so that my employees on the floor could make that happen,” he says. “The second reason is that in tough times it kills you to do a job twice because you have to rework it. It is actually cheaper to do it right the first time. It’s the old adage: ‘measure twice, cut once.’” In this marketplace, every cost savings, scrap reduction and quality improvement gives the company an edge.
Not only have Marlin and its customers benefitted from the timesavings and quality improvements of the CNC investment, but the company also has discovered an added, unexpected benefit. Because of the amount of time available on the CNC router machine, Marlin has begun selling its services as a fixture maker. “Now we are starting to make fixtures for other companies. We are so fast at fixturing that we’re on the other extreme,” says Greenblatt. “It’s become a revenue generator.”
(800) 361-3408
www.axyz.com
Benefits
