The Checkline LS-5-12000 linear strobe is for use with rewinders, slitters and similar process equipment in the label printing and process market, as well as vibration analyzers, balancers and metal producing equipment. The Xenon U-tube has a lifespan of 200 million flashes and flash duration is less than 5 microseconds. Flash rate can be externally triggered by a sensor/controller on the process machine, using industry-standard TTL-type square wave signal rates of 208 hertz and higher. Or, the LS-5-RCU remote controller can be optionally specified for this purpose. The strobe operates using 24-volt DC. It can use power available on the machine, or the company’s AC-DC power adapter.
Electromatic Equipment Co. Inc.
(800) 645-4330
www.checkline.com
Linear Strobe
