The Maxima ML-3500 Series ultraviolet lamps use micro discharge light (MDL) technology, plus a unique filter and bulb/reflector, to deliver up to 10 times the UV-A (365nm) output of conventional HID inspection lamps. With these lamps, NDT inspectors can see surface defects, hydrocarbon contamination and other flaws that escape less powerful lamps. The lamps are available in 120 volts, 230 volts, 240 volts and 100-volt AC versions, as well as battery-operated versions that include a 12-volt, 7 amp/hr rechargeable battery, which will operate the lamp for two hours. A battery charger and carrying case are included.
Spectronics Corp.
(800) 274-8888
www.spectroline.com
Reply 70
