The KD-2306 is a noncontact linear displacement measuring instrument based on balanced bridge eddy current technology. It makes high-precision static and dynamic measurements, and supports ambient, moderate temperature and cryogenic rated sensors. Applications range from lab work to production and process automation. The DIN rail mount packaging makes the system ideal for integration into OEM equipment and industrial control applications. The KD-2306 senses both ferrous and non-ferrous metal targets. The RoHS-compliant, CE-marked system includes the electronics, sensor and interconnecting cable. Standard sensing ranges are from 0.02 inch to 2.4 inches, with 0.01% FS resolution or better, and nonlinearity as little as 0.25% FS. More than 30 sensor models are available, including single and dual coil, shielded and unshielded designs.
Kaman Measuring and Memory Systems
(800) 552-6267
www.kamansensors.com
Reply 67
