The Model E2 leak testing instrument has a built-in Micro-Flow sensor (IGLS) and two levels of fill/balance for faster test cycles. The device allows the operator to remotely monitor leak tests over a network, using the E2 Ethernet connection and Leak–Tek program Version 5.0. The unit has a touch screen with graphical color display. The instrument is for use in pressure applications with leak rates from 0.1 cubic centimeter per minute.
ATC Inc.
(317) 328-8492
www.atcinc.net
Reply 69
