GigE Vision Camera
The GC750 Gigabit Ethernet camera connects directly to the Gigabit Ethernet port on the host computer and does not require a frame grabber. The result is a low-cost alternative to analog camera/frame grabber options. The camera incorporates a scan CMOS sensor with global electronic shutter suitable for capturing high-speed motion events. The CMOS sensor used in the GC750 has excellent near IR sensitivity. The camera runs 60 frames per second at 752 by 480 resolution via a GigE Vision-compliant Gigabit Ethernet interface. The camera is available in both monochrome and color models supporting both 8- and 10-bit formats. The color version of the camera outputs fully interpolated RGB as well as Bayer 8, Bayer 16, YUV411, YUV422 and YUV444 image data. The GC750 includes external trigger and sync I/O, and an RS232 port for controlling peripheral devices. It also includes auto-iris control output for video-type auto-iris lenses.
Prosilica
(604) 875-8855
www.prosilica.com
Reply 697
Prosilica
(604) 875-8855
www.prosilica.com
Reply 697
