The Spectroline Optimax 365 is a cordless, rechargeable true UV-A LED flashlight for nondestructive testing applications. The flashlight uses ultra-high-flux LED technology to produce a nominal steady-state UV-A intensity of 18,000 microwatts per centimeter squared at a distance of 15 inches. Powered by a rechargeable battery, it provides 90 minutes of continuous use between charges. The LED lifetime is 30,000 hours.
The flashlight weighs 11.8 ounces and is ergonomically designed to provide comfort and freedom of movement during inspections. It has a corrosion-resistant anodized lamp body, and comes with UV-absorbing safety goggles, a belt holster and smart AC and DC battery chargers. The AC charger is available in 120-, 230-, 240- and 100-volt versions.
Spectronics Corp.
(800) 274-8888
www.spectroline.com
