Line Scan Camera
The XH8800 Series line scan camera is designed for imaging high-energy X-ray and gamma ray scanning applications. The XH8800 is used to image large, dense objects such as metal castings and steel objects whose thickness can range from four to 12 inches. It is available in seven active sensor lengths ranging from 154 to 1,542 millimeters including a broad mix of resolutions ranging from 96 to 30,720 pixels on centers as small as 50 microns. Other detector lengths can be special ordered with virtually no maximum length limit.
X-Scan Imaging Corp.
(408) 432-9888
www.x-scanimaging.com
