The CSDS60CM3 is a high-definition camera targeting the industrial vision marketplace. Able to achieve high picture quality with smearless imaging, the model CSDS60CM3 also can successfully serve as a low-cost HDTV studio sub-camera, as well as in observation, teleconferencing and point-of-view production applications. It incorporates a ?-inch complementary metal-oxide semiconductor (CMOS) progressive scan color sensor with operator-selectable choice resolutions of either 1280 by 1024 or 1280 by 720 at a maximum frame rate of 60 frames per second (fps).
Toshiba
(949) 770-TELI
www.toshiba-teli.com
