Vision & Sensors - GigE
The GigE Option
GigE Vision multicasting provides powerful and unique machine vision capability—when used correctly.
Source: JAI
Normal GigE Vision operation. A single host controls a camera and receives the image stream over a GigE connection.Source: JAI
Multicasting mode enables secondary hosts to receive, display and/or process any image information that is being streamed to special multicast IP addresses.Source: JAI
Any number of secondary hosts can be connected to the multicast stream to easily add distributed processing capability.Source: JAI
In this simple example, a two-camera application transmits image streams to multicast IP addresses via a network switch. Host 1 receives both streams, while Host 2 is configured to access only the image stream from Camera 1. Source: JAI
Failure to properly configure multicasting traffic can cause both cameras and hosts to receive all transmitted streams, exceeding available bandwidth and severely impacting performance. Source: JAI
Normal GigE Vision Streaming
What is Multicasting?
So why use multicasting?
Working with multicasting
Pitfalls to avoid
Make Multicasting Part of Your Toolbox
TECH TIPS
