A non-contact linear measurement sensor with a wide range of available outputs has been introduced by Solartron Metrology, a unit of AMETEK, Inc. The new Orbit LT Laser Triangulation System is designed to support quality control in high volume precision manufacturing applications requiring verification of every part.
Orbit LT sensors can be connected with other Solartron probes via the company’s Orbit network or the newer Orbit ACS (Automation and Control System). Other available outputs include Modbus, RS232, RS485, USB, Ethernet TCP, Discrete NPN, PNP, logic and analog (0-10 VDC). The sensors provide 15 mm range, 45 mm offset, with 0.1% F.S. (Full Scale) accuracy. The heavy duty casing is IP 67 rated. Easy installation includes teachable settings for different surfaces.
Solartron Metrology
+44 (0) 1243 833333 | [email protected] | www.solartronmetrology.com
