Photoelectric Sensors
The new sensors feature compact construction, allowing them to be mounted easily where space is limited. The bright red LED light source is clearly visible over long distances and provides an aid to alignment. Setting up the sensors is intuitive, and is made even easier with a large sensitivity adjustor for use with a standard size screwdriver. When the sensors are in use, instant visual confirmation of their operating status is provided by an LED indicator with a wide viewing angle.
Omron’s E3FA and E3FB photoelectric sensors include through-beam versions with ranges up to 20 m, retro-reflective versions with ranges from 0.1 to 4 m, coaxial retro-reflective versions with ranges up to 500 mm and three models of diffuse-reflective sensors with ranges of 100 mm, 300 mm and 1 m. All types are suitable for flush mounting.
OMRON
(866) 88-OMRON
