Laser Tracker
Hexagon Metrology’s Leica Absolute Tracker AT402, an ultra-portable 3-D Absolute Tracker, can be utilized for fully guided 3-D measurement processes, as well as traditional inspection tasks. The new laser tracking system is optimized for ease of use, so operators can focus on the measurement task instead of complicated settings, such as the number of samples or measurement frequency. The Leica AT402 is ideal for large volume, precision measurement applications performed by industries such aerospace, power generation, heavy equipment and other manufacturers that produce large components and assemblies.
The compact measurement system and its case weigh less than 33 lbs. and can be used anywhere, inside or outside, due to its IP54 rating for ingress protection against dust and fluids often found in industrial environments. With a full 8 hours of battery life, the tracker’s hot swap batteries enable the operator to install fresh batteries without powering down the system, keeping user productivity high.
Hexagon Metrology | www.hexagonmetrology.us
