Vision & Sensors - Products
Visual Inspection Camera
Wohler USA recently added three new visual inspection camera systems to their product line: the VIS 250, VIS 350, and VIS 400. They’ve also introduced a new camera system accessory: the L 200 Locator.
Wohler’s VIS 250 Visual Inspection Camera offers you a clear view when space is tight. You’ll love its flexibility as it easily negotiates bends and turns. Its integrated locator transmitter precisely pinpoints damage and saves you time. This camera is ideal for analyzing household wastewater pipes of 1 ½-in. diameter and larger. It can also be used to inspect dryer vent systems, ventilation lines, hollow spaces (e.g. in front-wall installations), and flue gas lines.
Wohler’s VIS 350 Visual Inspection Camera takes their proven design a step further with new features. The home function helps you maintain your sense of orientation when troubleshooting and the position of the camera head is indicated on a vibrant display. The VIS 350 covers a wide range of applications. Use its pan-and-tilt camera head to inspect wastewater lines, house connections, flue gas systems, ventilation lines, false ceilings, and more. The VIS 350 also comes equipped with two rechargeable batteries, giving you greater mobility when on the job.
Wohler USA | (978) 750-9876 | www.wohlerusa.com
