Marposs G25 Gaging Probe
The Marposs compact G25 gaging probe was developed to gauge parts while still fixtured in the machine in case reworking is required. When used for gear grinding, the G25 gauge identifies the part location and tooth spacing for purposes of aligning the part with the grinding wheel prior to grinding. The same device is then used to scan the profile of the finished part in a continuous cycle.
Marposs Corp.
marposs@us.marposs.com
(888) 627-7677
