Fluke 830 Laser Shaft Alignment Tool
The Fluke 830 Laser Shaft Alignment Tool delivers precise shaft condition measurements and actionable results. The tool is fully capable to perform vibration testing, infrared thermography, and other predictive maintenance measurements. The Fluke 830 operates in three simple steps 1) setup which determines a machine’s dimensions; 2) measure which takes readings as the laser rotates around the shaft; and 3) diagnostic results which include corrective figures for proper alignment. The interface of the 830 is easy to understand and does not require extensive alignment knowledge.
Fluke Corporation
(425) 446-5905
www.fluke.com/lasershaftalignment
