Handheld Calibrator
The New Heise PTE-2 handheld calibrator features include a USB port, SD card, backlit LCD and an onboard loop power supply. Like the original, the PTE-2 incorporates Quick-Select modules to measure pressure in ranges from 0.25 inches H2O through 10,000 psi and temperature over a wide range with RTDs or thermocouples. A current and voltage input can also be displayed simultaneously with two other measurements, while 16,000 records can be datalogged for historical reference. An IP65 rated enclosure, agency approvals and a list of other front-panel features make the PTE-2 the all-in-one solution for field calibration.
Heise
(800) 328-8258
www.heise.com
