Portable CR System
Carestream NDT has launched a new HPX-PRO Portable CR system designed to enhance mobile imaging with exceptional image quality, improved productivity and easy portability.
This next-generation CR system is lightweight at just 35 lbs, and its compact size and design make it easy to move in and out of tight spaces such as mobile inspection labs. The HPX-PRO is ideal for a wide range of imaging with scan resolutions of 25, 50 and 100 microns.
Working in rugged and remote environments requires a CR system built for the task. The HPX-PRO was subjected to months of extreme testing including temperature swings, 0 - 4G accelerometer, dropping, banging and being transported in trucks (and airplanes) to validate its durability. During these tests it never needed to be recalibrated and the unit performed flawlessly after each test cycle.
The HPX-PRO can be operated off main power (AC 110/ 220v) or by using the on-board battery which can provide up to four hours of standby time and 45 minutes of run time. A replaceable air filter keeps out dust and dirt, and both the entry and exit feed trays fold up to seal the unit when not in use. An optional vehicle mounting bracket can be attached to a work surface enabling the HPX-PRO to be quickly snapped into a secure position for safe transport in a lab on rough roads.
Carestream NDT
(888) 777-2072
www.carestreamndt.com
