Optical Shaft Measurement System
Mahr Federal has introduced a new addition to their growing family of optical shaft measurement systems. Competitively priced and designed to provide fast, accurate, fully automatic measurement of smaller shafts and turned parts directly on the shop floor, the MarShaft SCOPE 250 plus features a highly accurate matrix camera with four million pixels. The system measures parts up to 250 mm in length and 40 mm in diameter with an accuracy that is previously unknown in this market segment. An MPE (Maximum Permissible Error) of less than 1.5 microns + L/40 when measuring diameter and an even more impressive 3 microns + L/125 when measuring length is significantly more accurate than other systems using line cameras.
One key to the system’s speed is the state-of-the-art, high-resolution CMOS matrix camera with a live image field of view of 40 x 24 mm, enabling it to capture an entire part diameter in a single view. With Z-axis positioning speeds of up to 200 mm/second and an image acquisition rate of over 120 images per second, measurements are performed faster than the blink of an eye. Zoom functions allow measurement of the smallest details such as chamfers and radii, which can be difficult and in some cases even impossible to test, with conventional measuring methods.
MarShaft SCOPE 250 plus can be operated entirely on the integrated touch screen, or via a keyboard and mouse if desired. MarWin®-based EasyShaft™ software enables the precision measurement of diameters, lengths, contour features, and form and position tolerances in accordance with standards, and offers many new evaluation and documentation options, all with an easy-to-use intuitive user interface. EasyShaft runs on the Windows® operating system and is compatible with other Windows applications and printers.
The touchscreen gives direct access to positioning, programming, measurement and documentation, including the use of “swipe functions.” The clear simple user interface helps keep track of everything users need to know, and many functions, such as loading measuring results or adding feature measurements, can be activated simply by clicking on obvious icons.
Mahr Federal Inc.
(800) 343-2050
