Vision System
Teledyne DALSA announced its next generation BOA 2 Smart Camera featuring higher resolution imaging, dual-core processing and embedded iNspect Express application software. The BOA2 smart camera is a complete vision system with more pixels, power and integration flexibility for automating parts and assembly inspection.
BOA2 is offered with 2, 3 or 5M pixel resolution. For very high speed applications, the CMOS sensor format can be changed to achieve inspection rates of up to 80 parts per second. The 2M model supports an optional integrated LED ring light with built-in collimators that provide powerful, uniform lighting across the inspection area. The sensor supports standard C mount lenses which, together with the optional LED light, can be enclosed within a protective cover to safeguard against accidental damage or tampering. The BOA2 is rated for use in harsh industrial environments and provides several mounting options on the front, back and side surfaces.
At the heart of BOA2 is a high performance, 1.5 GHz dual core processing engine for executing user configured solutions. System memory resources include 2 GB bytes of solution storage and 1 GB of program memory. The embedded iNspect Express application software supports standard factory protocols, such as EthernetIP, Profinet and Modbus for interfacing with complementary factory products and control networks. The physical interfaces include Gigabit Ethernet, RS-232 serial, opto-isolated inputs and outputs, all of which can be connected using standard M12 factory cables. A DIN mountable breakout module is offered to simplify control panel wiring.
The BOA2 is available immediately. For more information on product specifications and ordering details, visit the BOA2 page on the Teledyne DALSA website or contact your Teledyne DALSA regional sales representative. For a downloadable image of the camera, please visit Teledyne DALSA’s online media kit.
Teledyne DALSA
