The new FlyMarker mini is the landmark fourth generation of the battery-operated, FlyMarker dot peen marking system. Housed in an ergonomically designed, compact unit weighing just 6 lbs, the mini can be carried throughout the shop with no annoying power or air cables needed. Its strong magnet and powerful battery rapidly produce durable and unforgeable markings on nearly any material ranging from plastics to aluminum to steel. The versatile mini also marks round parts, with automatic height compensation up to 5mm.
The marking files can be programmed via self-explanatory software on the unit itself and includes storage space for several hundred files. Alternatively, one can create the marking files using optional PC-software and then transfer to the mini using its built-in USB-interface. Logos, data matrix codes, bar code scanners, and a solid column frame for conversion to a tabletop unit are just a few of the many optional accessories.
Equipment Sales Co.
(800) 255-6046
