Videoscopes
Titan Tool Supply, Inc., announced the introduction of its new line of TVT Series videoscopes to provide high-quality remote visual inspections for quality control. Lower in cost than comparable videoscopes, the new TVT line includes five different models with working lengths from 1m (40”) to 3m (118”) and three diameters (2.8mm, 4.5mm and 6mm). Titan Tool states that the 2.8mm diameter model enables inspections through extremely small openings. The videoscopes are designed for use in aviation maintenance, casting inspection, cavity inspection, diesel engine repair, gasoline engine repair, locomotive maintenance, ship maintenance, and other areas and application where remote visual inspection is needed.
The new TVT Series videoscopes feature an easy-to-use mechanized (rather than manual) joystick that uses input to directly control camera articulation. This results in smooth and accurate control of the articulating tip with immediate response to the joystick inputs. It also allows the camera tip to be steered through narrow bores, channels, and through complex curves, according to the company. The camera will hold its position even when pressure on the joystick is released.
The new TVT Series videoscopes also feature a 4.3 in. monitor with resolution from 160,000 to 440,000 pixels and image sensor of 1/18, 1/10, or 1/8 in. depending on model. Depth-of-field is 5mm to 50mm or 15mm to infinity with articulation either 2-way or 4-way (also depending on model). The sheathing is abrasion-resistant, and each unit is packed in a heavy-duty case that also includes an 8 GB SD card, Li-ion battery pack, and a battery charger.
Titan Tool Supply, Inc. | (716) 873-9907
