Calipers
Mitutoyo America Corporation announces the renewal of our 500 Series IP67 ABSOLUTE Digimatic Coolant-proof Calipers.
Product highlights include:
- Incorporates Mitutoyo’s ABSOLUTE measurement system. No need to reset the origin.
- The automatic power on/off shuts down the LCD after 20 minutes of inactivity, but the ABS scale origin is unaffected. Power is restored to the display when the slider is moved.
- Can be integrated into statistical process control and measurement systems
- Larger LCD of 9 mm, a 22% increase in height for improved visibility
- Extended battery life of 5 years has been achieved due to low-current integrated circuit
- Easy to operate with advanced ergonomic design that uses only one button
- Battery cap does not require a screw driver for simplified battery replacement
Mitutoyo IP67 ABSOLUTE Coolant-proof calipers can be used in workshop conditions exposed to coolant, water, dust or oil. 100% air-leak test ensures every caliper conforms to IP67.
MITUTOYO AMERICA CORPORATION | (630) 820-9666 | MARKETING@MITUTOYO.COM | WWW.MITUTOYO.COM
