Buehler EcoMet 30 Grinder Polishers
Buehler is introducing the EcoMet 30 Semi-Automatic and Manual Grinder and Polisher for use in heat treat, automotive, aerospace, and electronic laboratory environments where fast reliable results are required in production environments. Quality control and lab technicians now have a choice of more robust semi-automatic or manual grinder polisher with the power to perform in high sample, high use environments.
The EcoMet 30 Semi-Automatic provides simple operation for grinding and polishing with an ergonomic base that is easy to clean. Constructed from solid cast aluminum, the EcoMet 30 range is designed for maximum robustness and reliability in the most challenging of environments. The EcoMet 30 Manual provides simple operation and includes a splash guard, ergonomic design and low bowl height for better control and comfort. The straight drain, removable bowl liner and quick remove platen make daily maintenance a breeze.
The EcoMet 30 semi-automatic version includes a user-friendly touchscreen interface, with all functions on the front screen without complicated menus. The pneumatic polishing head also has an easy load specimen holder and swing-out head to maximize efficiencies of use.
Buehler
(847) 295-65000
