Spectronics EDGE 13 Flood Lamps
Spectronics Corporation is releasing the first two models of the new EDGE™ 13 Series, a new group of fanless, LED UV-A, IP65 rated flood lamps. Each model is designed for overhead applications in non-destructive testing and fluorescent inspection. The first model being released today is the EDG-13SBLC, a fully ASTM E3022-2015 and Rolls-Royce 90061 compliant LED UV-A flood lamp for overhead non-destructive testing. The second model being released today is the EDG-13T, a non-compliant flood lamp perfect for NDT professionals who require a rugged, high-intensity lamp to spot fluorescent indications on large parts. Both EDGE™ 13 models come with 8-foot and 20-foot AC pow-er cord options and are available for every country-of-destination. All models are gangable and can share the same power supply – making it easier to expand the inspection area by joining units together.
Simply align the units together and use the gangable cord accessory to connect the units to the same power source. Every model in the EDGE™ 13 series comes with an easily mountable and adjustable bracket for modifying overhead inspection configurations. Additionally, every model comes with 13 Long-Lasting LED UV-A Lenses and is IP65 rated – signifying the unit can be fully covered in dust and suffer no intrusion. The IP65 rating also means the unit is protected against jets of water from all directions.
EDG-13SBLC Features and Technical Information:
- ASTM E3022-15 and Rolls-Royce RRES 90061 Compliant
- Units can be ganged together to provide an even greater area of coverage
- IP65 Rated
- Nominal steady-state intensity of 4,700 µW/cm² at 15 inches (38cm)
- Large coverage area of 14.5 inches x 13 inches with a minimum UV-A intensity of 1,000 µW/cm²
- Less than 1.0 foot-candle (11 lux) visible light emission
- Integral Black Light Filters
- Thermal Cut-Off Circuitry
- Certificate of Conformance included
- Validation Report included
- Unit Weight: 14 lbs (6.35 kg)
- Unit Dimensions: 11” x 14” x 9”
- The EDGE™ 13 is CE, CCC, RoHS, and WEEE compliant. Meets EN ISO 3059 standards for non-destructive testing
EDG-13T Features and Technical Information:
- High-Intensity flood lamp to spot fluorescent indications on large parts
- Perfect for use in the automotive, fabrication, machining, and oil/gas industries
- IP65 Rated
- Nominal steady-state intensity of 6,500 µW/cm² at 15 inches (38cm)
- Large coverage area of 17.5 inches x 16 inches with a minimum UV-A intensity of 1,000 µW/cm²
- Certificate of Light Output included
http://www2.spectronicscorp.com/e/220372/ndt-products-/98mjq/63748971
