Luxendo MuVi SPIM CS Microscope
Bruker announced the release of the Luxendo MuVi SPIM CS light-sheet fluorescence microscope for imaging optically cleared samples.
Bruker announced the release of the Luxendo MuVi SPIM CS light-sheet fluorescence microscope for imaging optically cleared samples. The MuVi SPIM technology allows fast, long-term imaging of large samples with highest resolution and optical sectioning, as well as minimized photodamage. By means of physicochemical clearing techniques, the optical properties of usually opaque samples are modified to render them transparent, while keeping their structure intact. The Luxendo MuVi SPIM CS brings together the best of light-sheet fluorescence microscopy and tissue-clearing techniques, and provides new solutions in sample mounting, sample size, and optics to enable best-in-class, high-quality 3D imaging of cleared samples.
The Luxendo MuVi SPIM CS is an extension of the MuVi SPIM capabilities to enable 3D imaging of cleared samples. The Cleared Sample Module is an add-on consisting of an exchangeable cleared sample optical core unit (octagon) and an overhead sample-positioning unit installed on the microscope’s top plate. The octagon can be easily removed from the microscope for maintenance and cleaning of the sample chamber and objectives that have been exposed to the mounting solution. The sample chamber and detection unit in the octagon can be adapted to suit experimental needs in terms of sample size and detection lens configuration, providing highest flexibility.
The Luxendo MuVi SPIM CS features sample mounting ‘from above’ for easy sample access and optimized travel range suited for various mounting methods (e.g., hook, plate, pin or cuvette), a large sample chamber compatible with a broad range of solutions used in different clearing protocols, as well as flexible illumination and detection configurations to meet varied application needs. As a result, the Luxendo MuVi SPIM CS can image a great variety of samples at high speed and high resolution.
To handle the vast amount of data produced by the light-sheet technique, the new Luxendo LuxData comprehensive data processing and storage solution provides fast transfer and large-capacity storage, and also leverages multi-core- and multi-GPU-based processing. This holistic approach supports the complete acquisition, storage, and processing workflow for high-resolution image data from Luxendo SPIM microscopes.
Bruker | www.bruker.com
Luxendo | www.luxendo.eu
