Starrett AGD Group 1 Digital Indicators
The L.S. Starrett Company has introduced a range of Digital Electronic Indicators conforming to true AGD (American Gage Design) Group 1 dimensions, providing the ability to replace traditional mechanical indicating applications in the smallest AGD size specification class. Starrett 2700 Electronic Indicators are the first digital gages to match true AGD Group 1 dimensions (1.70 in./ 43mm diameter).
Starrett 2700 Indicators feature a 1.70 in. diameter, 270 degree rotating bezel, allowing different user viewing preferences. The gages are available in two displays ‒ a single LCD Numeric IQ model (the largest of its class) with low battery warning and programmable ratios, or a Numeric/ Analog AD model showing the two displays simultaneously.
Gages feature a .400 in. (10mm) travel, accuracy of ± .0001 in.(0.002mm) on the F2715 models and accuracy of ± .0002 in. (0.004mm) on the F2714 models. The gages can store and view 200 readings internally. Stored readings can be downloaded with included software and a USB style cable. Starrett 2700 Digital Indicators have a CR2032 cell long-life battery that can last up to 3,000 hours under typical use. Gages are output-compatible for SPC documentation via cable or wirelessly using a Starrett DataSure® Data Collection device.
(978) 249-3551
