ZIVID One+ For Easy 3D Image Processing
ZIVID One+ for easy 3D image processing from EVT.
The EyeVision 3D software supports the new ZIVID One+. The 3D color camera generates point clouds with shape-by-shade 3D technology. With the EyeVision 3D software point clouds can be evaluated. Therefore Pick & Place applications with a robot, 3D inspections in production and research can be easily solved. This requires point clouds in high quality and accuracy. The ZIVID detects objects with single- and multi-frame-imaging. The sensors have a 2.3 megapixel sensor and is used to capture RGB-color-, 2D- and 3D-images. Therefore an automation solution can reliably detect, inspect, classify, and pick&place objects.
For reliably solving Pick & Place applications especially the cycle time is a critical element. The ZIVID One+ 3D cameras support fast 3D capture up to 12 fps color point cloud capture. Native 2D color capture reaches up to 50 fps.
The 3D camera has an aluminum housing with IP65. Therefore a reliable use in humid and dusty work environments is guaranteed. The 3D sensor is already pre-calibrated and with the EyeVision 3D software all point cloud images can be evaluated exactly.
EVT
