High QA Inspection Manager Version 5.1
High QA has released Version 5.1 of its innovative Inspection Manager™ (IM) software. This latest version features next level Quality 4.0 standards, increased automation and enhanced workflows.
Inspection Manager is a comprehensive database-driven solution for manufacturing quality management throughout the production and supply chain process. The centralized database contains manufacturing inspection plans, ballooned drawings, inspection results, First Article Inspection (FAI) and Statistical Process Control (SPC) reporting and incorporates all quality requirements that enables accountability, traceability, and repeatability. The streamlined quality inspection process eliminates paper documents, prevents human interpretation errors, standardizes best practices, and increases efficiencies in collaboration and compliance on the shop floor.
Version 5.1 continues support for key industries and compliance standards including Aerospace (AS9100/EN9100, AS9102), Automotive (QS-9000/ISO/TS16949, APQP, AIAG guidance), Medical (21CFR, ISO 13485), Defense, Heavy Machinery, Oil and Energy and others with multiple best practice standards.
Inspection Manager v 5.1 delivers several enhancements to improve workflows, efficiency and traceability.
Integrated AQL based sample planning in Inspection Manager Version 5.1 provides a more efficient workflow with data and plans in one centralized database. Set up a sampling plan once and use it across multiple jobs, lots, and orders. Modifications to the plan can be simply made with just a few clicks and are immediately visible. Integrated AQL based sample planning allows for repeatability, scalability, and consistency. Inspection Manager sample planning is based on MIL-STD-105 and Z1.4 AQL standards and supports many other common AQL tables.
The new Manufacturing Key Sets feature works the way you do. It enables you to group dimensions by cutting tools the same way parts are made on the shop floor. Dimensions affected by the same cutting tool are added to a Manufacturing Key Set group and color-coded on the print for easy identification of each group. The most critical dimension in each Manufacturing Key Set is marked as a Key dimension and made identifiable on the ballooned print. When the Key dimension passes inspection, the remaining members of the Manufacturing Key Set are marked as passed. Manufacturing Key Sets is an integrated feature working together with AQL Based Sample Planning and the centralized database system to maintain the integrity of the GD&T and inspection results data. The all-in-one system provides full, automated traceability to the source.
Control access to sensitive part data with Inspection Manager’s integrated security control access system. Define security groups by location, department, role, or individual user to restrict part record access based on a ‘need to know’ or ITAR requirements. Add or remove users from access groups in a central location eliminating the need for the IT department to manage separate secure and unsecured servers.
More advancements in IM v5.1 include the ability to see inspection status for a part showing completed, to be inspected and failed results. Included with the new release are expanded materials, process management and template libraries.
High QA
