Teledyne Flir introduced the latest addition to its polarized Blackfly S GigE camera lineup – the BFS-PGE-123S6P-C.
This new 12MP model is well suited for applications dealing with reflective and/or challenging lighting conditions. Ideal for use cases like traffic systems, UAS (unmanned aerial systems), inspection lines with transparent or reflective parts, and other uncontrolled lighting environments.
The camera pairs the new Sony IMX253 MZR sensor with an easy-to-use glare reduction feature built into the Spinnaker SDK, making application development and deployment fast and easy. These new GigE cameras with Power over Ethernet (PoE) also take advantage of the new Lossless Compression feature, delivering up to 14 FPS at full resolution without compromising on image quality. Weighing in at just 36 grams, it is significantly lighter and more compact than competing offerings in the market.
Detailed specs include:
• 12 MP Global Shutter CMOS featuring on-sensor polarimetry
• Delivers resolution of 4096 x 3000 @ 10 FPS (up to 14 FPS with Lossless Compression enabled)
• Smallest and lightest: 29 x 29 x 30mm, 36 grams
• Spinnaker SDK can dynamically reduce reflections from non-metallic surfaces
• Long distance cable options for unique application setups
• Features Power over Ethernet (PoE – GigE)
Teledyne Flir
https://www.flir.com/
