Smart Vision Lights JWL150 External Light
Smart Vision Lights (SVL) announced the release of its JWL150, the first in the new Camera-to-Light (CTL) series. Unlike other external illumination products designed for machine vision cameras and smart cameras with built-in illumination that falls short, the JWL150 delivers an intense, compact light source with an integrated camera mount.
Compatible with most major machine vision cameras, the JWL150 can be directly connected and controlled through a camera’s trigger output. Systems integrators often deploy external bar lights or use built-in camera lights, but external lighting takes up valuable space and built-in lights often provide insufficient lighting. In machine vision systems that are tight on space, the JWL150 delivers an intense yet compact lighting option.
The IP65-rated bright field light features a working distance of 500 mm up to 2000 mm; 10-, 14-, and 30-degree lens options; and built-in Multi-Drive™ technology, which offers both continuous operation and OverDrive™ mode. In continuous operation mode, the JWL150 can provide constant light or be triggered following the camera’s exposure signal. OverDrive™ mode delivers up to 6 times the continuous power with a low-latency response and fast strobe durations down to 10 s.
The JWL150 features a batwing design that illuminates a larger area than built-in lighting systems and produces a greater light output that easily combines with polarizers, diffusers, and other optical elements that reduce light output. The new JWL150 targets disparate machine vision applications, with a particular focus on high-speed conveyors that require bright illumination at long, stand-off distances.
Smart Vision Lights
www.SmartVisionLights.com
