Smart Vision Lights JWL150-DO Lightgistics Machine Vision Light
Smart Vision Lights (SVL) introduces the JWL150-DO Lightgistics Series light, now with Hidden Strobe technology, which delivers the benefits of strobing without the distraction and disorientation associated with LED strobe lights.
Hidden Strobe technology allows LEDs to internally self-trigger thousands of times per second, pulsing faster than the human eye can perceive and creating the illusion of continuous light. The technology maximizes machine vision systems while protecting employees from the disorientation caused by flashing lights.
Designed specifically for performing challenging high-speed, accurate barcode reading and optical character recognition (OCR) with packages in highly reflective plastic wraps or shipping bags, Lightgistics lights feature Dual OverDriveTM technology — which combines SVL’s Deca OverDriveTM and standard OverDriveTM engines and allows end users to attach polarizers that retain exceptional light output while handling any speed.
The JWL-150-DO delivers an intense, compact light source with an integrated camera mount that can be directly connected and controlled through a camera’s trigger output. The JWL150-DO features an onboard charging capacitor designed to ensure powerful bursts of energy with a low consistent electrical draw. The IP65-rated bright field operates using a working distance of 500 mm up to 2000 mm; 10-, 14-, and 30-degree lens options; and built-in Multi-Drive technology that provides both continuous operation and OverDriveTM mode.
Smart Vision Lights
SmartVisionLights.com
