Smart Vision Lights RHI200-DO Lightgistics Machine Vision Light
Smart Vision Lights (SVL) introduces the RHI200-DO Lightgistics series light, which features 64 LEDs in a 205 mm x 205 mm ring light for intense uniform lighting at long working distances of up to 2000 mm. Equipped with Hidden Strobe technology, the light delivers all the advantages of strobing without the disturbance and disorientation often linked to LED strobe lights.
Hidden Strobe technology allows LEDs to automatically trigger thousands of times per second, pulsating at speeds imperceptible to the human eye and generating the appearance of uninterrupted illumination. The innovative technology helps maximize the abilities of machine vision systems while safeguarding employees from the disorienting effects commonly associated with flashing lights.
Lightgistics lights specifically address the challenges of accurate high-speed barcode reading and optical character recognition (OCR) on highly reflective plastic wraps and shipping bags. Dual OverDrive™ technology utilizes SVL’s new Deca OverDrive™ and standard OverDrive™ engines, which together allow end users to easily attach polarizers that maximize light output in high-speed conveyor systems.
The RHI200-DO is an OverDrive™–only light source with a high-intensity ring light. Its integrated camera mount fits most common machine vision cameras and can be directly connected and controlled through a camera’s trigger output. The RHI200-DO’s onboard charging capacitors ensure powerful bursts of energy while maintaining a low consistent electrical draw. The IP65-rated bright field operates at working distances between 500 mm and 2000 mm with 10-, 14-, and 30-degree lens options.
Smart Vision Lights
SmartVisionLights.com
