ABB Modular Large Robot Portfolio
ABB Robotics is continuing the expansion of its modular large robot portfolio with the introduction of the new IRB 7710 and IRB 7720. The new robots, combined with recently launched IRB 5710-IRB 5720 and IRB 6710-IRB 6740, offer a combined total of 46 different variants capable of handling payloads between 70kg-620kg, to give customers a new level of flexibility, greater choice and performance in their operations.
ABB’s new IRB 7710 and IRB 7720 robots offer 16 new variants and are ideally suited to support applications across various industries. Operators can choose from a wide range of ABB robots to ensure they have the ideal variant to handle various applications for electric vehicles (EV), hybrid, and traditional car production – spanning from press automation, body-in-white, EV battery construction, and final assembly. These robots are perfect for high payload assembly, such as giga casting, high speed press tending and palletizing, as well as high accuracy contact applications, such as machining and friction stir welding.
Powered by OmniCoreTM, the new robots achieve class-leading motion control with path accuracy down to 0.6mm, even with multiple robots running at high speeds of up to 1600mm/s and moving payloads of up to 620kg. Customers can also benefit from an up to 25% reduction in cycle times1 further enhancing productivity and quality. In the automotive industry, the all-new IRB 7710 with the latest OmniCore controller, will boost the production output of robotic press lines from 12 to 15 strokes per minute to produce 900 parts per hour. Furthermore, in the construction sector, the new robots will support the growth in modular construction, capable of constructing steel building frames and surface finishing, with improvements in speed and quality.
The IRB 7710’s energy efficient design in combination with OmniCore’s re-generation technology achieves up to a 30% energy reduction1, while the built-in power pack can relay energy back to the grid.
• New IRB 7710 and IRB 7720 alongside wider portfolio offer new levels of flexibility and greater choice with almost 50 variants
• New series delivers up to a 30% reduction in energy consumption1
• Latest robots ideally suited for use in industries such as automotive, general industry and logistics
ABB Robotics
https://new.abb.com/products/robotics/robots/articulated-robots/irb-7710
