MaxxVision High-Speed Cameras
MaxxVision GmbH presents two new CoaxPress high-performance cameras from the Canadian manufacturer IO Industries.
Redwood 5MP: Compact performance with up to 3876 fps @ 720p The Redwood 5MP colour camera uses a 5.2 megapixel sensor in APS-C format and achieves impressive frame rates of up to 872 fps at full resolution (2560 x 2016 pixels) in 8-bit mode. Even at a higher bit depth, the camera remains extremely fast with 714 fps at 10 bit and 583 fps at 12 bit. At 8-bit and HD resolution (1280 x 720), the CoaxPress camera even achieves up to 3876 fps. The maximum frame rate of 17,241 fps is achieved at a resolution of 128x32.
Redwood 21MP: For applications that require both high resolution and speed, the Redwood 21MP with its 21-megapixel sensor (5120 x 4096 pixels) offers frame rates of up to 230 fps at 8-bit, 183 fps at 10-bit, and 152 fps at 12-bit. With Full HD resolution (1920x1080), up to 2032 fps are possible at 8 bits.
The combination of high resolution and extremely fast frame rates opens up new possibilities in various areas, including:
• Scientific Research: Applications such as microsecond imaging, temporal analysis, motion tracking, particle image velocimetry (PIV), high-speed microscopy, biological motion analysis, and flow visualization.
• Industrial applications: machine vision, manufacturing inspection, process monitoring, quality control, production line analysis, defect detection, process optimization, and industrial automation.
• Sports & Entertainment: Slow-motion footage, action replays, broadcasting, event reporting, sports analysis, high-speed film production, and visual effects.
• Automotive and aeronautics: crash tests, impact analysis, aerodynamic studies, vehicle dynamics, flight tests and aviation tests.
Both camera models feature:
• Global Shutter for distortion-free shooting
• Flexible CoaXPress 2.0 interface with coaxial or fiber optic connection
• Multiple mount options (C-mount, F-mount, M52 x 0.75, active Canon EF mount)
• Extensive image processing functions such as white balance, black balance and gamma correction
"With the new cameras from IO Industries, we are entering the realm of high-speed image capture," explains Sayed Soliman, Managing Director of MaxxVision. "The combination of high resolution and extremely fast frame rates opens up new possibilities for our customers for their applications."
MaxxVision GmbH
www.maxxvision.com
