Platinum Tools Mini OTDR Tester
Platinum Tools® announced the launch of its new PT-OTDR-100 mini OTDR tester. The PT-OTDR-100 is scheduled to ship in October.
“The Platinum Tools PT-OTDR-100 mini OTDR tester provides a simple to set up and easy-to-use solution for OTDR testing,” explained Charles Hoskins, V.P. of Product Development. “The PT-OTDR-100 includes a 5.5 inch OLED touch screen for easy viewing of cable tests and can save and export your OTDR tests. This unit will perform OTDR tests, OPM, VFL, and laser source functionality for fiber optic cable, and will also perform continuity testing and TDR for Category cable.”
Additional specifications include:
• Auto Testing with Event Map
• OTDR Test Range 3m - 105km
• Laser Source, OPM and VFL functionality
• OTDR tests exportable as SOR or PDF files
• Includes RJ45 remote for copper cable testing
• Multiple adapters for fiber optic cables included
“The PT-OTDR-100 analyzes the measuring curve of optical fibers, providing insights into uniformity, defects, fractures, joint couplings, and other properties,” Hoskins continued. “It measures optical fiber attenuation, connector attenuation, and faults, and displays loss distribution along the fiber length. It is essential for optical fiber construction, maintenance, and monitoring.”
Platinum Tools
www.platinumtools.com
