Harold G. Schaevitz Industries ILPS-13Z Miniature LVIT Position Sensor
Harold G. Schaevitz Industries announced the release of the ILPS-13Z Series Miniature Linear Variable Inductive Transducer (LVIT) Position Sensor. Made in the USA, this innovative sensor is designed to deliver exceptional performance and reliability for a wide range of industrial and laboratory applications, including automotive R&D, motorsports, motion control, medical, military, and aerospace.
The ILPS-13Z series sensor features a ruggedized design with a ½” OD stainless steel housing, incorporating an inductive coil and spoiler combination that eliminates the wear and dithering issues commonly associated with potentiometer-type sensors. The integrated amplifier electronics remove the need for an external signal conditioner, streamlining installation and operation.
ILPS-13Z Features:
• Contactless Operation: Eliminates wear from dither or cycling
• I/O: 15-30VDC input with an option of four different analog outputs including 0-10VDC and 4-20mA
• Versatile Range: Available in ranges from 0.1 to 8 inches (2.5 to 200 mm)
• Compact and Durable: 0.5 inch (13 mm) diameter stainless steel housing, rated to IP-67
• Flexible Configurations: Radial cable exit version with swivel rod eye ends, and axial termination versions with either M12 connector or cable
The ILPS-13Z series is constructed from industrial-duty materials to resist dust, water, temperature, shock, and vibration, ensuring reliable performance in the harshest environments.
For added convenience, a Mini Connector can be installed on the adjacent wire lead termination end upon request.
https://www.hgsind.com/miniature-linear-position-sensors-landing-page
